Neff dishwasher S515T80D1G/51 stops after 20/30 minutes with auto & eco light flashing.. no fault code 🙁 it does get warm and it drains when cancelled, checked the e19 valve. Have I missed something as not sure why no fault code
Sorry Dave I have been away.. The dishwasher has filled, washed and heats up then just stops.. If I cancel the programme it drains no problem. No fault code which is strange as this dishwasher does display time.
ok
when it fails does it just stop or does the display go blank too ?
if you open and close door does it restart (was thinking door sensor problem ) had one doing similar things and it was the top rack not going all the way in, this put pressure on the door and as it got hot it popped open just enough to stop it
