Neff dishwasher bottom door seal
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts Neff dishwasher bottom door seal
  • #20766
    geoffmackay
    Model S5443XI GB/07 FD7807 part no for door seal please.
    #188303
    Re: Neff dishwasher bottom door seal
    298534 – £18 list.
    If it’s leaking out of the corners, it’s almost always the bottom rotor, not the seal…..
    Add http://www.bshappliancecare.com to your favourites – follow links to “Quickfinder” – very helpful.
    geoffmackay
    It is leaking from bottom corner of door, havent seen machine, customer wants to buy part and fit himself.
    Thanks Chris
    #188305
    gegsy
    geoffmackay wrote:It is leaking from bottom corner of door, havent seen machine, customer wants to buy part and fit himself.
    Thanks Chris
    Had one the other day similar age, and was the lower door seal. Where they attach to lip along the door well they distort an become detached allowing wash water to seep out.
    Its not a bad job to fit, customer will love it 😈
    When they call you because they have given up, all you have to do is
    1/ Release door springs from base and remove front panel.
    2/ Undo 2x torx hinge retainer screws from left and right side
    3/ Remove old seal assembly
    4/ Clean along floor of stainless inner below door where seal would come in contact.
    5/ Offer one side of new seal plastic assembly BETWEEN stainless of door and hinge it MUST be sandwiched and re attach with the torx screws the door inner and hinge; and then the other side.
    6/ Lip new rubber onto door well
    7/ Re attach door tension in base.
    8/ Look smug after you have shown them how easy it was 😆
    HTH
    geoffmackay
    Nice one Greg, weve already been given the job. Cheers mate.
