Greetings, experts of UK White Goods and thank you in advance for your words of wisdom.
Mine is a Neff S5444X1GB/23 dishwasher, built-in with the 2007-era apartment we’ve just moved into.
I started it with a handful of rinsed dishes and cups in it. It ran and then stopped – the dishwasher tablet was damp but not dissolved. Now, whenever I start a programme, the drain pump just runs continuously, and the “Check Water Supply” light (no. 7) comes on after a while.
When I lift the float, on releasing the float the drain pump stops for a split second, then starts again. Indeed, the drain pump runs with the door open.
I’ve cleaned the mesh micro filter, pulled out a shard of glass from the bottom. True, I managed to break a glass with the dishwasher on the first use.
I removed the impeller cover, and couldn’t find any debris around the impeller, and I can see the impeller turning when I power on the dishwasher with the cover removed.
I don’t hear or feel any activity on the Bitron Type 902 aquastop valve when I start the machine.
This also exhausts my recently-gained knowledge about dishwashers.
What would be my next steps here?
