NEFF dishwasher no heat
  • #52065
    MARIO
    Can anyone help have got a neff dishwasher model S5555X0GB/70 going through prog but no heat and no fault code showing . Checked element 23.5 ohms and micro switch ok , so fitted timer still no heat what now element ?
    #310481
    ELTEL
    Re: NEFF dishwasher no heat
    have you checked the stats
    #310482
    MARIO
    Where are the stats ,are they is on top of element with plastic cover over it ? Thanks for helping I need it on this one
    #310483
    ELTEL
    A sensor NTC or thermistor is located on top of the heater unit#
    good look
    Terry
    #310484
    rocker
    have you checked the pc board, check first common fault. you can usually repair.
    #310485
    S1MON
    Dry joint pcb
    #310486
    MARIO
    Have replaced timer pcb .Seems to be no voltage at element or stats sensor .Are the sensors available as spare part or do they come complete with element . Thaks to everybody for there help . Thought this job was going to be so easy
    #310487
    ELTEL
    Sensor N.T.C Code Number 165281 Retail £26.59
    Complete Heating Element Code Number 5031684658008
    Retail £85.55
    Both items are from Connect Distribution
    Code numbers are from list
    Hope this helps Terry
    #310488
    loopey
    broken wire at front door harness more than likely. had one last week
    hth phil
    #310489
    MARIO
    Checked cables and they seemed ok .Will try sensor thanks to everybody for there help will let you know how it goes
    #310490
    MARIO
    Just to let you know it was the ntc sensor and dishwasher is now working ok. Thanks to everyone for there help
