Re: neff dishwasher not emptying???
Hi max
Firstly check the filter in the base paying particular attention to underneath it – lift out the filter, then lift out the plastic frame it sits in and have a good look in the bottom, often there is an accumulation of muck down there.
If the machine trips then that is another fault, most likely the heater or less likely the wiring harness at the base of the door – either of these require an engineer to diagnose/repair
Clive
