Neff dishwasher not filling S51M53X0GB/16
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Neff dishwasher not filling S51M53X0GB/16
  • #99474
    JulianT
    I have a Neff integrated dishwasher that does not fill with water. It shows error E24 and the check water supply icon in the display. When I start the dishwasher all water is drained out but it does not fill with any fresh water. I have taken the fill chamber or metering tank off and cleaned it becuase it was full of gunk. The dishwasher then seems to work for one cycle. It will fill and wash as you would expect. Second time though the same e24 and check water icon appear. I have checked the supply and drain hoses and there are no blockages. This leads me to think that I may have a sensor issue and the dishwasher is not detecting that the water has been drained correctly. I am not sure how to check this. Any advice would be gratefully received. Thanks.
    #476532
    e24 and 25 are both drain errors
    to detect the unit has drained the board detects the current flowing to the drain pump. when the unit is empty the pump sucks air and draws less current
    a faulty pump that is worn can also draw more current fooling the board that its still full
    or it could be the board
    is it draining all the water ?
    JulianT
    Thanks Dave for your reply I will check tonight to see how much water is drained. Could it be that there is something trapped around the pump which causes it to work harder and draw more current? I have had a good look in the sump area and cleaned out any debris but I have not removed the pump.
    #476534
    JulianT
    Hello Dave when it drains the water I can see a small amount left in sump. It is about 2 cm from the lowest point in the centre of the sump. If I completely empty the sump using a sponge the dishwasher will then start a wash cycle. I stopped the cycle before it finished but it did fill with water and pump the water through the spray arms. Does this mean that the pump is failing?
    #476535
    JulianT wrote: Does this mean that the pump is failing?
    possibly is all i can say
    all you can do is swop it and see but its a chance like all fault finding
    gen pump part no is 611332
    on the neff site for £32.78
    JulianT
    Hi Dave
    Do you stock the drain pump? I can see a pump with the SKU number 00611332 on your website but my model is not shown in the list of models that this part fits.
    Julian
    #476537
    if the part is linked to the part number it should be correct
    as for stock I am over 230 miles from the shop and have no stock access
    you would need to message them
