Neff dishwasher S51M632GB/93 not draining completely
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Neff dishwasher S51M632GB/93 not draining completely
  • #98723
    snig
    Neff dishwasher washes ok but leaves too much water in tub at the end of programme. Drains down fine when i try it and new pump fitted recently to try to cure same fault. Not backfilling. Not sure what else to try
    #473542
    is it overfilling ?
    was thinking impellor jug may be missing a few beats making it add more water
    snig
    doesn’t appear to be when i’ve watched it but possibly. Then again when i watch it pump out it drains so well i think it would cope with that. Bit of a puzzle
    #473544
    some units have problems with extended hoses
    is the hose laid in an odd way so it could airlock slightly ?
    snig
    Not that i can see. With the original pump, sometimes it would try several times before it got going, hence the reason i changed it. ??
    #473546
    well it should be a 3 phase pump, i would check the connection to the board, if its lost a phase it may cause this
    after that it may well be a board fault
