Neff Dishwasher S54M45X5GB/01 Filling fault
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Neff Dishwasher S54M45X5GB/01 Filling fault
  • #61973
    grooster
    I’ve been out to a Neff dishwasher today S54M45X5GB/01 and it seems to be overfilling and when the safety overflow gets high enough it empties and then refills continuously.
    I have noticed that this machine has a flow meter instead of the older pressure switch in the matrix. Now I have had a look at the flow meter and the wheel inside is turning, but with never having any problems with one of these on a BSH machine before (plenty of problems with whirlpool ones) unsure what to look for.
    I wasn’t sure whether it could be the motor not cutting in quick enough to take the water out of the sump and causing the machine to think it was overfilling but the motor seems fine, not seized and the machine is only 3 years old. The pipes and the matrix are completely grease and algae free.
    Then again I also thought that it could be the PCB.
    If anybody has any experience with these machine or indeed this flow meter and advice would be greatly received.
    Cheers guys
    Nick
    #348216
    bubs
    Re: Neff Dishwasher S54M45X5GB/01 Filling fault
    Had a couple overfilling on a faulty flow meter.
    Cheers
    Graeme
    #348217
    bosch-engineer
    Its the flow meter (impeller jug).
    #348218
    washtronics
    had it on a siemens and it was the flow meter, same machine different brand
    #348219
    grooster
    Thought as much, just needed a little reassuring from you guys.
    Thanks for your help. I’ve just ordered one, hopefully the first of many.
