Neff Dishwasher S6409N3GB/19
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Neff Dishwasher S6409N3GB/19
  • #16997
    johnnyhoz
    Would anyone have a drawing for this model.
    The problem is no power to the heater element, very difficult to get to the stat conections may be I can pick up the connections on a board if I had a drawing it would help.
    John
    #172479
    Re: Neff Dishwasher S6409N3GB/19
    John,
    The heater is powered via the main Power Module (488708) in the base and that could be the source of the trouble?
    If you give their Technical Dept a ring on Monday (0870 242 6660) I’m sure they can fax you a copy of the wiring diagram should you wish. They will post a copy to you if faxing isn’t an option too. 🙂
    #172480
    johnnyhoz
    Thanks Martin
    will do on Monday
    John
    #172481
    gegsy
    When you say you have no feed to heater, you realise it goes through a microswitch (situated inbetween heater amp tags). If you have insufficent water in the wash cycle this switch will not activate for safety reasons and will not complete the feed to heater.
    whitevanman
    Just a comment gents,
    Recently had heater ass oc with this design, ordered part (complete assy)and fitted only to find out would not heat, would not heat due to microswitch fitted/suplied – when open sc / when closed oc.
    WVM
