Neff Dishwasher S6409N3GB/19
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Neff Dishwasher S6409N3GB/19
  • #17473
    johnnyhoz
    The original fault was it would keep on running indefinately and would indicate 1minute left to run then after a few minutes it would indicate 4 minutes left to run. I checked the heater which was ok but there was not voltage present and the stat was open circuit, fitted a new stat, it now definately is heating but it still over runs with the same read out on the display, has anyone had this before?
    John
    #174528
    johnnyhoz
    Re: Neff Dishwasher S6409N3GB/19
    Further observations detected slow water intake, maybe this would give the 1 minute 4 minute readings on the panel and not moving on ?
    #174529
    gegsy
    To be honest it sounds like the usual gunge scenario johnny.
    If there was a filling problem you would be getting an “F” in the display.
    Check the metering unit and 1 ft ribbed pipe at front of appliance for signs of crud.
    johnnyhoz
    Thanks Greg will do
    John
