Re: Neff Diswasher S5443X2gb/42 tripping RCD
paullove wrote:I have found a new pump for £50, so considering replacng the failty one.
You’ll have to be careful here. Is that just for the motor or just the pump section or the motor/pump complete? If you found it on Fleabay then good luck with that.
paullove wrote:I have not removed the pump so not sure how difficult it is to replace,
It’s a challenge for the amateur that’s for sure.
paullove wrote:or if need any more parts to complete the job.
That’s often the reason why many DIYers have appliances in bits for days on end whilst they find more parts are required. But one part you’ll need is a thin jubilee clip the fits between the pump housing and heater.
Good luck …!
