Neff Double oven
  • #29641
    dna
    U1661N0GB/O2
    Hi Ive got a repair with a neff double oven I have found that the control
    unit for the main oven has blown. Have check all elements and fans all are sound. Just wanted to know if anything else could of blown it or could it have been a surge. dont want to order because from the neff site its £170.
    #223949
    SWERV
    Re: Neff Double oven
    oven lamp?????
    Merv
    #223950
    dna
    Hi merv
    Have you had this b4 seems a bit excessive if a lamp could do that much damage.
    #223951
    SWERV
    Yep had this a couple of times, my partner done one this week in fact.
    Merv
    #223952
    dna
    Thanks merv is there anywhere else i can get this part its bloody expensive
    #223953
    clivejameson
    Being the said partner i can confirm that i did do one this week 8), yes it was the lamp that did it BUT, the board damaged was the power/relay board which has no sensitive electronics on it and a couple of tracks which were blown off i successfully soldered out.
    The particular board is situated at the left hand side at the top behind the facia, looks like it comes as a complete assembly with transformer etc but with care can be unclipped from it’s mounting on the assembly to get access to the tracks.
    HTH?
    #223954
    Simon46
    Was it fusebox or rcd consumer unit?
    S.
    #223955
    clivejameson
    Can’t rightly say Simon, but i see what you’re getting at…an rcd/mccb might have saved the electronics whereas a fuse might not?
