Neff Double Oven Cooling Fan
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Neff Double Oven Cooling Fan
  • #98081
    simonpw
    Had problem with fan motor buzzing on and off. Fan ran, then stopped, then buzzed momentarily then kicked in again. Found that the stat was shorting against the light housing (that was def not the buzzing). i moved it off the housing, then heated up the oven but still the same so assumed the stat was damaged. Replaced that with the correct part from Whitegoods and fitted. Now no fan motor buzzing. But if oven very hot fan will stay on but goes of I feel too soon. much sooner then before. Then it will come on again. So manually keep the fan on until cool down. I noted the temp printed on the stat is 100c and i wonderer if this is too high as i have seen other mentions of 65c. It is not identical to the original – though the packet say Original – which i have now seen on another parts web site.
    Thanks. Simon
    #470801
    What model is it please, nobody will be able to see anything or help without that vital info?
    simonpw
    Thanks its a U1442NOGB
    #470803
    Whereabouts was the one you replaced and with what part number?
    simonpw
    As mentioned it was on the light housing (top oven) and part 00154836
    #470805
    That’s the correct one so there’s probably something else up with it.
    simonpw
    K – sorry been away. So can you confirm if the corect temp on the stat when it connects the power to the fan should be at 100c or 65c
    #470807
    Sorry, I don’t know as I don’t have access to tech info on the oven but it, depending on where you look and possibly what model, can be a cooling fan stat or thermal limiter.
    simonpw
    OK – Thanks
