NEFF Double oven FAULT .
Home Forums Public Support Forums Help And Support Cooker And Oven Forum NEFF Double oven FAULT .
  • #21280
    manflu
    Hi any help would be much appreciated !!
    I have a NEFF Double oven model FD8001
    The fault is the bottom oven does not heat up , the fan kicks in when the temp gauge is turned on but the oven itself does not heat , also the lamp inside does not illuminate either .
    I have removed the back cover to check for fuses etc , but could not find any .
    Does anyone have any idea what could be at fault ?
    Rob ..
    #190275
    gegsy
    Re: NEFF Double oven FAULT .
    The FD is the manufacture date. What we need is the ENR or FNR number so we can assist you further.
    manflu
    Hi , The ENR No. is u1421nogb/01
    and the FD No . is 8001
    Hope you can help
    thanks rob
    #190277
    gegsy
    manflu wrote:The fault is the bottom oven does not heat up , the fan kicks in when the temp gauge is turned on but the oven itself does not heat
    Here should sort that for you http://www.ukwhitegoods.co.uk/modules.p … cts_id=383
    Here should sort this for you http://www.ukwhitegoods.co.uk/modules.p … Path=26_53
    I hope you made safe that appliance preferably at fuse box and for all future investigations :plug:
    HTH
