Hi any help would be much appreciated !!
I have a NEFF Double oven model FD8001
The ENR No. is u1421nogb/01
and the FD No . is 8001
The fault is the bottom oven does not heat up , the fan kicks in when the temp gauge is turned on but the oven itself does not heat , also the lamp inside does not illuminate either .
I have removed the back cover to check for fuses etc , but could not find any .
Does anyone have any idea what could be at fault ?
Rob ..
