Neff Double Oven Fault
Home Forums Public Support Forums General Enquiries And Questions Neff Double Oven Fault
  • #88178
    Seamstress
    Our Neff double oven does not heat up fully on the fan setting. We have already replaced the thermostat and the switch but this has not fixed the fault. It heats up fully on other settings, but when used on the fan assisted setting it gets a little bit warm but not up to temperature. Hoping someone can suggest which part to replace next. Many thanks in advance.
    #437245
    Re: Neff Double Oven Fault
    to enable someone to suggest something post the Enr number of the oven
    SAMURI
    The most likely fault would be the fan oven element.
    Bob
    #437247
    Seamstress
    Seamstress wrote:Our Neff double oven does not heat up fully on the fan setting. We have already replaced the thermostat and the switch but this has not fixed the fault. It heats up fully on other settings, but when used on the fan assisted setting it gets a little bit warm but not up to temperature. Hoping someone can suggest which part to replace next. Many thanks in advance.
    Enr No: U1461N2GB
    #437248
    Seamstress
    SAMURI wrote:The most likely fault would be the fan oven element.
    Bob
    Thank you, we’ll have a look at that.
    #437249
    Seamstress
    electrofix wrote:to enable someone to suggest something post the Enr number of the oven
    Thanks Dave, the Enr number is U1461N2GB. I’ve tried to add it to my original post, not sure if that’s worked. I’m new to this.
    #437250
    Almost certainly (as Dave suggests) the fan element (Part no: 00499003) will need replacing.
    #437251
    Seamstress
    Martin wrote:Almost certainly (as Dave suggests) the fan element (Part no: 00499003) will need replacing.
    Thanks Martin, we’ve checked it and it’s not heating up. New part now ordered from Whitegoods.
    Many thanks for everyone for their help.
    #437252
    thekeymurphy
    Apologies, just found this and wanted to say thanks as I’ve run into the exact same issue and this thread helped resolve. Don’t think there’s anything this forum can’t do.
