Neff double oven U1ACE2HN0B/01 – Cooling fan turns itself on
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Neff double oven U1ACE2HN0B/01 – Cooling fan turns itself on
  • #102398
    asp11
    This works fine in normal use but it randomly turns on the cooling fan motor during the night and sometimes an hour after use.
    I’ve not visited yet just been messaging him as I’ve not come across this problem before……… any ideas please?
    #488635
    from what i can see of the parts list this unit uses a resistor that heats up and operates a stat to get a delay start and stop on the cooling fan. thats where i would look first
    SWERV
    I had this issue sometime ago and spoke to someone at BSH technical.
    Here is the link to my post,
    https://www.ukwhitegoods.co.uk/forums/forum/trade-member-forums/trade-technical-spare-parts-forums/trade-technical-enquiries/870863-neff-oven-u1ace2hn0b01
    Basically, there is a NTC repair set (part number 12027485) that cured the issue.
    Merv
    #488637
    asp11
    Thank you both for being so helpful
    #488638
    asp11
    SWERV wrote:I had this issue sometime ago and spoke to someone at BSH technical.
    Merv
    I found the part number available from ASWO but there doesn’t seem to be any actual ceramic or button stat included, is this correct?
    #488639
    the ceramic and button stat is a different part.
    i assume that the thermistor must sense the temp and turn on the creamic which then heats up and operates the button stat. when the oven is turned off it taked time to cool down the stat so the fan runs on for a while
    cant find this thermisor in the part list but Swerve’s oven seems to be the same number so it must be there
    SWERV
    On the BSH parts list, it is down as a sensor NTC (position 0984). I was told to fit all the parts supplied in the kit, which I did.
    Merv
    #488641
    SWERV wrote:On the BSH parts list, it is down as a sensor NTC (position 0984). I was told to fit all the parts supplied in the kit, which I did.
    Merv
    ok see it now
    not much electronics in this so where does it plug in. only elctronics i can see is display
