I need to removed the lower fan oven door to re-place a broken glass. panel . Not sure how to remove the door. from the oven,.has I have already broken the inner glass.. I do what to cause any more damage.. any advice welcome Cheers John
Lock the door tabs when the door is open, semi close the door and the door will then slide up and off if you have locked the hinges correctly.
When you have the door apart, note the orientation of the glass panels.
