Neff DW
  • #29736
    S1MON
    I have been to a neff dw S4350X0GB/07
    Another eng. has recently replaced the cir pump, but the initial fault is still happening to the machine. Now it doesnt complete a cycle, but today i managed to get it too drain out but as soon a that had happened it did nothing. I was getting no power to the door switch switch but the pcb selector switch to the right was lite and receiving V’s. I could not get any volts from the timer to the door switch.
    It all seems a bit odd, anyone done much with these as it seems to has two seperate timers one on the left and one in the middle.
    It apears to be heating fine. also the float swith doesnt see to engage whe it is set to overflow?? I checked the switch and it is working correctly.
    #224279
    gegsy
    Re: Neff DW
    This beast has two water matrixes and the only problems I have had with this type were –
    1/ Broken wire/s in the door loom at the bottom of the door bend
    2/ Worn microswitch/s on either water matrixes.
    3/ Gunge in metering hose
    4/ Aquastop activated or faulty
    5/ Burnt out or charred connections on the door microswitch
    S1MON
    Ok cheers ive checked the door switch is ok, wiring loom looks ok have checked round by the door and internal hose is clear. I will look at the other points.
