Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Neff DW error code
- This topic has 7 replies, 3 voices, and was last updated 12 years, 12 months ago by
RocketMan.
April 11, 2013 at 8:11 am #74969
RocketMan
ParticipantHi
Got a Neff integrated DW S51E50X0GB/16 FD 8911.
Customer tried to use it 3 months ago and it didn’t work so left it until now. I went yesterday and customer wasn’t too sure of faults other than not disolving detergent or washing very well. So tested it yesterday. Gutted a hand full of crud from both wash arms which now work. It fills, empties, heats, dispenser works and insulation test ok (at plug). It sounds like the water distributer is working. Accepts programmes ok, cancels/resets ok.
Customer came back to me, I remember, it was stopping mid programme. She tried to use it and now fault code is 3rd of 5 programme lights and stopped with water in the bottom. I’m presuming it’s aborted the programme and this is a fault code.
This is a combined heater/circulation pump.
April 11, 2013 at 10:42 am #393446Martin
ParticipantRe: Neff DW error code
Check Water LED is that? If so, base flooded probably. 🙁
April 11, 2013 at 11:03 am #393447RocketMan
Hi Martin,
No, got piccie from customer. Just middle program button is lit. That’s the Eco50 button. Check water light is not lit on the picture.April 11, 2013 at 2:43 pm #393448Martin
That ain’t a fault code but just the prog she set.
April 11, 2013 at 3:28 pm #393449RocketMan
If it’s a flooded base, sure the pump would kick in as part of the anti-flood mode?
April 11, 2013 at 3:49 pm #393450Martin
RocketMan wrote:If it’s a flooded base, sure the pump would kick in as part of the anti-flood mode?
You answered that question earlier. So we’re not talking flooded base…time to move on and start more head scratching on this one!:(
April 11, 2013 at 8:29 pm #393451nomadPaul
Its worth checking the installation. Any slight ‘twisting’ of the chassis can cause problems with door alignment and on these appliances , ifs imperative that the door alignment is spot on. The door doesn’t need to open to stop the machine and the increased internal pressure as it heats up is sometimes enough to stop operation.
When it happens again , ask the customer to just put pressure on the door without opening it and see if it fires back into life .
April 12, 2013 at 8:27 am #393452RocketMan
That’s a thought, I’ll ask her to run it again and see what results we get.
Thanks for that 🙂
