Guys Ive got a 6 year old Neff fully int d/washer(you know the one, no Mod number to hand,sorry) that i cant get to empty!! before you all bombard me with the obvius, i have changed the pump, cleared the big side chamber, i’ve also blown and cleared out the waste pipe, ive even taken the anti return black flap off, i can then blow from one end and get bubling water in the sump!!i can get it to drain eventually but the flow is so so slow, i ask you if i need to change or clean out the side chamber as it is a bit clogged up in the top left side(by the air valve thingy) but ive had hundreds like that and never had to changed one yet!!
I know it seems like a no brainer but it cant be the module can it?????
