Neff DW PCB
  • #93040
    pmb
    Hey guys I have a blown PCB on a Neff S51M53X1GB/03 and I am not sure what has caused it. It’s blown around the copper coil you can see in the picture, which is next to the mains power cord connection. Could this be a power supply problem? Any pointers are appreciated.
    Thanks, Darren
    #452972
    Re: Neff DW PCB
    It may well be a power supply issue as it is around the voltage rectifier area of the board. Also the 2 white relays directly above that fused area are the heater relays. So it could be associated with heater failure as well. Costly fix and no mistake. :snig:
    #452973
    pmb
    Re: Neff DW PCB
    Ouch I don’t want to do that repair. Thanks a lot Martin i appreciate your help
