Have a Neff integrated DW that sticks with 1 minute on the display.
It is a few years old, the model with the removable drain pump cover and plastic base. It sticks on all washes (inc auto), i am told just washing away.
I have had a quick look, fills, heats, drains ok. No dry joints on pcb.
Having looked at recent posts i am not sure if 01 is an error code (time out) or just 1 minute to go. anyone know?
If you try a search on that fault, there is some previous threads around on here for that fault.
Generally its caused by a blocked pressure system and transfer hose between pressure system and sump.
HTH 😉
Steve
If it`s stuck with 1 min left in display then it will be a blockage in the pressure system or sump hose. I`ve had four of these with this fault in the last month.
Thanks to all, going back Sat.
I didn’t notice the pump cutting in on fill so shall have a good look at the pressure switch. Have had one stick before.
Thanks again
Graeme
