Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › NEFF E-Nr S5543X2GB/17 No water from lower arm.
- This topic has 6 replies, 3 voices, and was last updated 13 years, 6 months ago by
trig748.
September 12, 2012 at 4:48 pm #71454
trig748
ParticipantHi. The dishwasher stopped cleaning the bottom tray items. I cleaned out the filters and the bottom spray arms. The micro filter ‘frame’ had broken up and parts of it found their way into the bottom arm. I ran the rinse programme.The arm does not spin. Removed it and water is not being supplied to this arm. I ran the hottest programme and still not spinning.
I am hoping that I can clear the blockage, if that is the cause, without taking the machine apart.
After reading some info on the internet I somehow triggered the door latch and now I can’t shut it but can opperate the machine (programme indicators not lit!) with the door open. How do I get back to normal opperation?
Is my machine the type that has alternate water supply to upper and lower arms?
Any advise much appreciated.September 12, 2012 at 7:35 pm #381080sorted
ParticipantRe: NEFF E-Nr S5543X2GB/17 No water from lower arm.
At the top center of the door use two thin blade screw drivers to flick the door latch catch back to the off position.
These d/washers have a water divertion valve to increase the water spray to the top or bottom spray arm.The divert motor mounted on the heater box could be faulty or jammed. remove bottom spray arm with torch look down theremaining tube if blocked by a metal disc try to manualy open with a long thin blade driver. test m/c this may not be a perminent repair. motor comes with heater box and is very expensive hope this helps.September 13, 2012 at 8:42 am #381081trig748
I have applied some leverage to the door latch to push it back but all I seem to be doing is distorting the area around it. Not sure how flicking this bolt works, it seems to be locked in position.
The bottom of the tube, where there is an offset hole about 6mm diameter, is not blocked by a disc.
September 13, 2012 at 9:41 am #381082Martin
trig748 wrote:The bottom of the tube, where there is an offset hole about 6mm diameter, is not blocked by a disc.
Nevertheless the heater box/water diverter unit is faulty and the only cure is to replace it. A costly fix by the way and NOT something for the DIYer to tackle. Contact your local independent repairer. 🙂
September 13, 2012 at 1:31 pm #381083trig748
Is it impossible for the broken filter parts to have somehow jammed the diverter unit mechanism? I would still like to know how to get the latch/bolt back to normal??
September 14, 2012 at 8:36 am #381084Martin
trig748 wrote:Is it impossible for the broken filter parts to have somehow jammed the diverter unit mechanism?
Yes!
trig748 wrote: would still like to know how to get the latch/bolt back to normal??
Loop some strong thin wire onto the door latch hook then gentle lift up to reset to the hook’s unlatched position.
September 14, 2012 at 4:31 pm #381085trig748
Martin wrote:
trig748 wrote:
Is it impossible for the broken filter parts to have somehow jammed the diverter unit mechanism?Yes!
Excellant. Won’t waste time on it.
Got it! Its a rotating latch. No wonder it wouldn’t lever back the way I was trying.
