Neff Fan Assisted Oven Tripping RCCB
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Neff Fan Assisted Oven Tripping RCCB
  • #70460
    nheather
    I have a problem with my Neff B1442N/10/GB Electric Oven. On certain oven settings, it trips the RCCB immediately.
    My immediate thought was a faulty element with an earth leakage, but as I thought about it I became puzzled.
    I believe that the oven has three elements – grill, fan and bottom.
    The RCCB trips immediately if any of these oven settings are selected
    Circotherm (fan assisted)
    Grill large area
    Grill small area
    The RCCB does not trip if either of these oven settings are selecetd
    TopBottom heat (convential)
    My immediate thought was that the grill element is faulty.
    But what is confusing me is why is the Circotherm setting casuing the RCCB to trip as I didn’t think it used the grill element.
    If it were the fan element that had gone then that would explain the Circotherm tripping but hot the grill tripping.
    I can’t imagine that two elements have failed at identical times.
    Any ideas?
    Many thanks,
    Nigel
    #378135
    Re: Neff Fan Assisted Oven Tripping RCCB
    without meters the fastest way of finding out is disconnection
    disconnect each element in turn and see if tripping stops
    nheather
    Yes I guess I’m going to do that – was hoping to be able to just reason it out and then order the right bit.
    What about measuring resistance. What’s the best test to do – I guess measure between terminal and earth – looking for infinite for a good one – I guess to trip the RCCB there needs to be at least 30mA so anything less than 800 ohms would do it.
    Cheers,
    Nigel
    #378137
    nheather
    Solved. Took it apart which was surprisingly easy and disconnected each of the elements in turn.
    All the elements share a common side (neutral I assume) which will be why I’m getting trips for different elements.
    Two things still puzzle me though
    (i) The failed element is the bottom oven which we have never used
    (ii) With the faulty element in place, the fan oven and the grill oven trip but the bottom one doesn’t.
    Anyway, since we don’t use the bottom oven, I’ve left it disconnected for now.
    Will replace it in slower time.
    Cheers,
    Nigel
    #378138
    if elements are not used they can soak up moisture over time which will make them trip
    you can heat the element that may dry it out and get it working again
    electrofix wrote:you can heat the element that may dry it out and get it working again
    Really? Is that wise? What amount of heat is required? And, without a test meter, how will I know if the problem has resolved itself?
    #378140
    which is why i used the word “may”
    only the other week I cured an oven that was tripping that had been sat in a garage for 12 months
    got elements out put them in another oven at 200 degrees for 2 hours
    lotusray
    it was common place 2 remove earth from a DAMP ELLEMENT for 15 mins get nice and hot and replace earth for an appliance that had been stood in a damp environment ie new build not sold for 18 months
    #378142
    Do the moderators think this good, sound advice for public consumption?
