Neff fan oven
  • #17200
    rocker
    Customer tells me when cooking in the top part of oven food cooks ok, but on the middle and lower shelves, cooking is uneven only one side appears to cook and the other side underdone.
    Door seals appears to be ok…hinges seem ok as door closes as normal..
    as anyone any thoughts please…john
    #173318
    Is the customer using baking sheets or anything else that could restrict airflow? 😉
    aqualectric
    Re: Neff fan oven
    Is the fan getting up to speed? Hot at the top seems to suggest heat rising due to it not being circulated fast enough by the fan. These fan motors take a few moments to get up to speed; I’ve had a couple run slow – similar fault.
    Hope this helps!! 😉
    Steve
    #173320
    gegsy
    Re: Neff fan oven
    Is door sealing and closing with a THUD??
    rocker
    Re: Neff fan oven
    many thanks for all your replys, very helpful, will look into these.
    cheers John
