Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › NEFF Fan Oven not working U1661N0GB/02
- This topic has 6 replies, 4 voices, and was last updated 9 years, 2 months ago by
easyeieio.
February 5, 2017 at 7:39 pm #90512
easyeieio
ParticipantHi all, I’m hoping someone might be able to help me diagnose what the problem is with my NEFF oven please – model U1661N0GB/02 . Inherited with a house we’ve moved into. There seems to be a problem with the fan oven mode , whereby it doesn’t get seem to get hot enough, we leave it for ages, but it never heats up fully.
Here’s what happens, turn oven on, in fan mode
, the temperature light comes on, and the oven light. The element seems to get hot, and when I open the door it can be seen glowing red ( see image below )
However after a short while the glow goes out. The main fan which also can be seen in that pic at the back is not spinning, but I can spin it freely if with my finger ( when the oven is cold! ) I can hear another fan somewhere , guess that’s something else? After a long time the oven heats up a bit, but not to full temperature and seems to get cold again really quickly.
The conventional oven
seems to work fine, gets up to temperature and cooks well ( on all other settings ) I’m guessing it might just well need a new fan / motor mechanism (this one I think https://shop.ukwhitegoods.co.uk/mtr295-oven-fan-motor ) but before I order it, I wanted to check in case there could be another problem. Should the element be glowing throughout , has that had it too, or is that happening because the fan is not working? Would it be a plan to order a new element anyway?
Any thoughts and ideas very much appreciated!
Many thanks
IanFebruary 5, 2017 at 8:04 pm #445055kaibart
ModeratorRe: NEFF Fan Oven not working U1661N0GB/02
Yes sounds like the main fan motor to me
February 6, 2017 at 5:34 am #445056easyeieio
ParticipantRe: NEFF Fan Oven not working U1661N0GB/02
Cheers, is it normal for the element to stop glowing red then after initial start up? Or is that because fan is not working?
February 6, 2017 at 8:28 am #445057Martin
Without the fan turning immediately the element switches on it will glow red and eventually, and very quickly burn out!
Fit a new fan motor and you might just save the day.
February 6, 2017 at 10:48 am #445058easyeieio
Thank you for the advice guys, I’ll report back once I removed it and (hopefully!) sorted it
Cheers
IanFebruary 17, 2017 at 10:28 am #445059thelearner
Many years ago I had the same problem. I bought a new fan motor.
When I removed the inner grill, I noted my wife had been clattering it hard with the trays/dishes etc, and one of the grills was bent back in causing the fan to be unable to turn.
I fitted the new motor anyway, and years later it’s still working fine – first step I would always do is remove the inner cover and see if the fan works with it removed.Remember when removing fan the nut is a left hand thread usually. Clockwise to loosen.
Good luck
February 17, 2017 at 10:59 am #445060easyeieio
Just thought I’d report back, and say thank you for the assistance. I took the oven out and replaced the fan, and the element too for good measure, whilst I had it in bits . The old fan span when pushed, but I guess the motor had gone – the whole thing was incredibly gummed up with nastiness from years of use. All cleaned up, installed, and working now, fantastic hot oven at last!
