Hi all,
First post here. I have a similar issue to this other post: https://www.ukwhitegoods.co.uk/forum…0x3gb-46/page3
I tried to add a comment to that thread but it didn’t allow me, maybe it is closed due to age.
The difference with my issue is that the machine does work and completes most of the cycle but appears to not wash as well as it used to and not finish the dry so everything is damp when the door is opened, and at that point the tap symbol is always flashing.
Any advice on what could be causing this?
I’ve checked:
– Water in, good pressure and clean filter
– Waste out, flowing well and no kinks
– Cleaned internal waste filter and checked impeller turns without any blockages
– Removed and cleaned out the thing on the side where water comes in through (was quite a lot of gunk in there)
Many thanks!
Tim
