Re: Neff Freezer
It’s either the compressor has failed to pump or there is a gas leak by the sound of it.
When you say fan, it’s the fan next to the compressor you refer to I assume ?
Directly in front of that is a block of pipework etc, make sure it’s not blocked with general gunk as the fan draws cool air through there to aid in the evaporation process.
Power off 1st of course :zap:
If all that seems OK, then my first lines apply, engineer to confirm though, repairs@ should be able to help 😀
