NEFF fridge – lots of water in the salad box?
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum NEFF fridge – lots of water in the salad box?
  • #56244
    blizeH
    Hey guys,
    Just got a bit of a problem with our NEFF integrated fridge – there’s a lot of water in the salad box (it’s like half full!) and this seems to be happening more often now.
    Anything worth doing or checking short of just buying a new one?
    #326676
    SAMURI
    Re: NEFF fridge – lots of water in the salad box?
    Have you checked the drain hole inside of the fridge it may be blocked.
    You can use curtain wire or a phillips screwdriiver to poke down the hole to clear it if the drain is blocked
    #326677
    blizeH
    Thanks so much Samurai (and sorry for the late reply!) – we’re having a look now, fingers crossed we can get something sorted (completely forgot until my dad started moaning about how we need a new fridge, oops!)
    Thanks again
    #326678
    nomadPaul
    Its worth checking to make sure the door is closing properly too. Being an intergrated machine , they sometimes slip back in the housing and the decor door then strikes the cupboard chassis first , stopping the door from sealing properly.
    Is there still ‘suction’ on the door when you try and open it i.e do you have to physically put pressure on to open the door or does it open really easily ?
    #326679
    blizeH
    Thanks paul (nice avatar by the way!) – I’ll check for that when I get home later too, although there definitely seems to be the regular amount of suction on the door, still worth a look, tyvm.
