Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › neff fridgefreezer side by side
- This topic has 6 replies, 4 voices, and was last updated 18 years, 4 months ago by
agro.
December 10, 2007 at 7:49 pm #32906
agro
Participanthave this model is k3965x0 not making any ice and not filling tay with water freezer working fine and the water valve ok and all clear any ides i think its the ice cube motor box at the top left which has the lever on it
December 10, 2007 at 9:16 pm #236768rickard
ParticipantRe: neef fridgefreezer side by side
This is a maytag with a neff badge the ice makers are all the same with different wiring connections. check if it is 120 or 240 volt though
December 10, 2007 at 9:21 pm #236769gegsy
ParticipantRe: neff fridgefreezer side by side
Usual suspect with this and the Maytag of this build was ice blockage within the delivery tube to the icemaker trough.
Try removing rear hose to that unit (from rear top right) and see if it is blocked or not.Greg
December 11, 2007 at 8:38 pm #236770agro
Participantchecked hose all clear anyone no the connect part number for the ice tray and motor
December 11, 2007 at 9:11 pm #236771gegsy
I would need the full enr number to help you further before you order anything, just to make sure 😉
December 11, 2007 at 11:37 pm #236772sorted
Take of white cover of ice maker.using apiece of insullated wire bared back 10mil at each end place the bare ends into holes “H” and”T”with the freezer door light switch taped/held closed. This should start the icemaker motor without the thermistor .If motor does not turn (plastic dial on front rotates) disconnect power supply remove front of module Check motor through with a meter,check all wire connections and contacts at cam check wireharness/fuse links into side of ice maker from back of freezer.
If not loose contact or wire no spare parts available will have to be new ice maker.
If motor turns but does not start to fill when the dial mark is at the four oclock position could be a solenoid valve at back of appliance or chocked pipe if the solenoid is buzzing.Have fun. Stephen
December 14, 2007 at 5:59 am #236773agro
thanks for the help sorted i,ll get round their and try
