Neff – Gas Hob Ignition Won’t Stop Sparking!
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Neff – Gas Hob Ignition Won’t Stop Sparking!
  • #96016
    MrsMc
    Hi, I have a Neff B14M42.3GB fan oven with a 4 ring gas hob. The top left hob rings ingnition to light the gas won’t stop sparking even after the gas has been turned off. I have turned the whole appliance on and off again but it’s still clicking away! Any advice will be most welcome, many thanks.
    #462073
    MrsMc
    Just found the Hob code: T22S46NO
    #462074
    It is probably one or more of the ignition switches on the gas taps that will be stuck for some reason. Those are under the hob top attached to the valves.
