Neff H5972N0GB/01 microwave
  • #90521
    Micky 32
    .. with built in oven. Hi all , The oven and microwave has stopped working. If i put the microwave on it comes on for a few seconds and then cuts off with a message ” appliance cooling”. Any ideas?
    #445079
    Re: Neff H5972N0GB/01 microwave
    these units are based on the Panasonic design using an invertor and magnetron. the unit detects if the mag has energised properly and if it does not it will abort the programme. Normally after 10 to 15 secs. it is likely that when the unit aborts it goes into the cool down mode.
    with your fault, if the microwave fuse is ok it is likely to be the mag ( but I cant promise ) . look at the magnets to see if one of them is damaged
    unfortunately you cannot be certain of the invertor until you put a new mag in
