I wonder if anyone can help me with this. Have been out and looked at this Combi m/wave, the fault is, on m/wave it shuts down after about 30secs. Ihave replaced the Mag and inverter and it is still oing the same 😕 .The mag had a burn/arc mark on the antenna, so thats why I changed it. I have checked all the door switches etc. Can anyone shed any light. If anyone has a service manual they could send, it would be appreciated.
Merv
First off , have you checked the 2 fuses on the power board ? I’d also check the support that the door switches are on to make sure it hasn’t moved backwards as it is adjustable and they do have a habit of slipping backwards. The switches might be working but if the support is too far back , they may not be making.
When you say the power board, do you mean the small board where the mains lead comes in? If it is I have checked them, and I also checked the switch holder, any other thoughts??.
merv
