Hi, I am looking for a service manual or circuit diagram for the above oven.. On switch on the display illuminates and then fades away within a few seconds. On dismantling the control panel I find a piece of track on the PCB adjacent to connector terminal 28, and looking as if it is linked to a relay, is burnt out. I am unwilling just to repair the track without first tracing the cause. The high voltage side seems ok on static test, and the door/interlock switches check out as ok.
Any help or advice most greatfully recieved
Patrick
