Neff heat pump element replacement
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Neff heat pump element replacement
  • #103593
    alexh
    The heating element on my neff dishwasher failed. It uses the 00651596 combined heater and pump. I’ve bought a new element but I’m struggling to install it in the pump. I cannot get it to seat in the o ring in the grey pump housing. Is there a trick to getting it in?
    #493863
    never fitted one of these but have had the odd pump apart and managed to seal it again
    as far as the manufacturers are concerned this is not a replaceable part so you cant get new seals which you would need to guarantee it seals
    alexh
    Thanks for your reply.
    What has worked is to remove the o-ring from the housing, place it over the heating element, place the element in the housing in the correct orientation, then force the o-ring into it’s groove from above. I used a ball end Allen key.
    The machine is back in action with hot water and no leaks.
