Neff heat pump thermistor wiring..
Home Forums Trade Technical & Spare Parts Forums Neff heat pump thermistor wiring..
  • #96852
    oscar123
    Changed the heat pump on Neff dishwasher and despite me carefully trying to remove the thermistor plug the wires came out 🙁 the plug top just fell off! four wires adrift all grey! If I take the plug off the module will it help to refit?
    Oscar123
    #465044
    boselecta
    Hi Oscar,
    Yes this has happened to me.
    I’m sure there are only three grey wires to the TOC though?.
    Yes if you take it off at the module it should be obvious where the wires go, the middle is the same and the wires on the left and right hand side will show themselves when you have it laid out on the desktop.
    Good luck
    #465045
    oscar123
    Thanks for the reply.. definitely four wires on this one but hopefully it will be the same! I did guess and put it on a cycle and it seemed okay but they have rang me back to say it is going E11 🙂
