neff hide/slide
  • #102731
    clockworkone
    B3ace4hn0b/35. First time looking at the door mechanism on one of these. What gives way on these and are there any common problems. Just looking for a heads up before i turn up and to try and make it look like i know what im doing
    #490241
    the wires inside the door are common to go but its not a cheap repair
    also getting the door off is fun, look up the owners manual
    1st you lock the trolleys then there is a ring either side you have to use a small screw driver to unlock
    Then it lifts off
    kaibart
    And the plastic profile rails break , a tip when taking the door off push handle slightly upwards and lift up as will come out easier p.s there are alot of parts that fail on theses doors so good luck
