Neff Highlite plate fitting T1722no/02
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Neff Highlite plate fitting T1722no/02
  • #90967
    mike100
    Trying to fit part no. 644726 that has 4 contacts on it
    There are only 2 wires so not sure which ones to use
    2 and 4 on old plate
    On new P1 is hard connected on element to 1a on temp limiter
    1b 2b 2a are free
    There is 4 on element
    Any help please
    Mike
    #446606
    Re: Neff Highlite plate fitting T1722no/02
    fairly simple to work out
    new ring has a hot light connection so is open circuit till it gets hot so you will only get the element resistance across 2 of them
    see picture put one meter lead here and go round the other 3 till you find the element
    the other 2 are for hob hot light, not used on yours at a a guess. 1 pair of contacts therefore should be open circuit and not connected to the ring element at all, ignore that pair. The other connection will go through the limiter and then through the element circuit itself. Use that one for one wire and the one on the side of the ring for the other- its a single ring so not too tricky. Does anoy me that they keep changing these connections. often find wired wont reach their new destinations.
