Neff Hob ignition sticking on
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Neff Hob ignition sticking on
  • #20096
    MattyD
    Hi folks,
    I’ve got a 4 ring Neff gas hob (Sorry, can’t find the model number but it’s about 9 years old) and on one of the rings the ignition stays on, even after the gas has lit. It just clicks away until either you turn the ring off again or jiggle the knob around until it stops.
    Is this a common fault? Is it possible to have it repaired and is it likely to be too expensive to be worthwhile.
    Many thanks
    Matt
    #185804
    gegsy
    Re: Neff Hob ignition sticking on
    Two scenarios here 😉
    1/ Hob top installed crooked when fitter did it causing knobs to chaff on aperture for knob
    2/ Ignition array that sits on each gas tap, faulty
    Please note that any work on this appliance must be undertaken by a Corgi engineer. Find a Corgi engineer here
    MattyD
    Thanks for your reply.
    Not sure it’s 1/ because it’s been working fine for years and all the others are fine. My suspicion is that overzealous cleaning has probably resulted in gunge being dripped down the hole until something has clogged up.
    For 2/ roughly how much for a new module + fitting?
    Thanks,
    Matthew
    #185806
    gegsy
    Without a model number no idea, but would still need a corgi engineer Im afraid.
