Neff hob & oven- Intermittent Sparking
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Neff hob & oven- Intermittent Sparking
  • #70616
    drewb
    Gas hob has started sparking occasionally on the front left ring.
    Its the same as when you turn the knob to ignite.
    Is this a common problem? Is it easy to fix?
    Thanks in advance
    From plate inside oven
    E-nr B1320N0GB/04
    FD : 8107
    B-AP22-7
    5750313105
    #378515
    nomadPaul
    Re: Neff hob & oven- Intermittent Sparking
    Your oven and hob are 2 seperate entities . That is the oven model number . You will need the hob number which is normally stuck on the underneath of the unit .
    #378516
    drewb
    Ok, I see. Is it easy to life the hob to see model number etc?
    I have given the hob a good clean where it sparks and it seems to have reduced the frequency of the sparking but it has not been eliminated.
    #378517
    drewb
    e-nr T2113N2EU/02 FD8104
    #378518
    drewb
    Would replacing the ignition transformer be the right thing to do here?
    #378519
    drewb
    Can anyone advise the next step apart from repairman or replacement?
    #378520
    don
    Sadly we cannot advise on DIY gas repairs forum rules apply.
    I would say it’s time for a Gas safe registered engineer to effect a repair. You could try our find an engineer function.
    Don
    #378521
    drewb
    Solved. Transformer replaced.
