Neff Hood D8900N0GB/01
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Neff Hood D8900N0GB/01
  • #84162
    B J Morris
    Switched lights on and bulb blew out of screw! Nothing works now. Didn’t trip out, fuse seems ok, control unit? Terminal box? Switch element?
    #424852
    Re: Neff Hood D8900N0GB/01
    if the fuse in the plug is 13amp then you have probably blown a hole in the printed circuit board
    it is common for kitchen fitters to leave the 13A fuse in the plug or spur box and ignor the manual which asks for 3 or 5A
    B J Morris
    Thanks Dave. Is the PCB in the terminal box next to the fan?
    #424854
    dont know on this unit. some are controlled by electronics some by simple switches
    if it simple switches then track blow in there. if its a seperate board then look there
    B J Morris
    Will do. Thanks Dave.
