Neff Induction Hob T4243XO/03
Does any one know if the cooling fan should operate as soon as the hob is turned on?
It is located above a draw so no appliances below; any one know what the ventilation clearance on the front grill should be customer says he can only just get his fingers between hob and worktop?
This hob only works on the right hand side, when you use just the left with one pan on either cuts out after 2 seconds.
Sounds like the main PCB but any suggestions?
Steven
