NEFF INDUCTION HOB T4243X0
  • #30812
    dna
    HI HAVE THIS PROBLEM ON THIOS HOB. THEREIS 240V TO BOTH THE INDUCTION BOARDS BUT HOB WILL NOT TURN ON. I ASSUME IT IS THE CONTROL MODULE. ANYONE HAD THIS PROBLEM BEFORE AND CAN CONFIRM THE MODULE AS IT IS EXPENSIVE.
    CHEERS
    #228554
    ANDYVIVO
    Re: NEFF INDUCTION HOB T4243X0
    Hi DNA
    Is there a magnetic pan on the glass when you are turning the hob on?
    Most induction units switch on without magnetic pans being placed on the glass, and turn off shortly after finding no pan.
    It could also be the glass has developed a smoke / dirt film on the underside (possibly from the airflow from a built in oven underneath ❓ ) and the sensors of the touch control cannot read throught the glass.
    Worth checking before ordering a module.
    Regards Andy
    #228555
    dna
    HI I FORGOT TO MENTION THAT THE CUSTOMER SAID THAT THE HOB WAS OFF AND IT TRIPPED THE ELECTRICS???? HAVE TAKEN THE HOB GLASS OFF AND TRIED IT WITH IT OFF BUT NO JOY.
    #228556
    gegsy
    What are the numbers after the XO??, so I can send you some stuff 😀
    dna
    THE NUMBERS AFTER ARE 03 CHEERS
    #228558
    gegsy
    Check your email and erm find your CAPS LOCK BUTTON 😆
    dna
    What email my ukwhitegoods one
    #228560
    gegsy
    Yea white.dna@virgin.net unless you want it to somewhere else 😉
    dna
    thanks very much.
    #228562
    superfix
    dna wrote:HI I FORGOT TO MENTION THAT THE CUSTOMER SAID THAT THE HOB WAS OFF AND IT TRIPPED THE ELECTRICS???? HAVE TAKEN THE HOB GLASS OFF AND TRIED IT WITH IT OFF BUT NO JOY.
    😯 😯 You haven’t put a pan directly on the hotplate have you 😯 😯
    BTW is it not still under it’s 2 year guarantee?.
    #228563
    dna
    no i haven’t
    #228564
    BSH-MAN
    No display is usually the control module, but I have had one of the induction modules cause the same fault. 😥 Sorry.
