Neff Induction hob T4842NO/01 no heat
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Neff Induction hob T4842NO/01 no heat
  • #14402
    Simon46
    Went to this today. RHS two plates failed and then a few months later the LHS two plates failed. When turning the heat setting up on any plate a relay click can be heard but the number stays flashing. Am i right in thinking the two power supplies at a cost of £447 have failed or will the plates have killed the PSU’s ?
    Regards
    Simon.
    #159298
    superfix
    Re: Neff Induction hob T4842NO/01 no heat
    Yup, sounds like power modules have gone.
    Does the appliance have a 5mm air gap below the work top and above the top of the drawer (full width of hob) as per installation instructions.
    If not this could be cause of the problem.
    #159299
    Simon46
    there was a 2 CM gap between oven and hob. Ran away from job and recommended BSH to the man. Thanks Boro
