Hmm, reading that suggests that the lock should indeed ‘switch itself on’ after 30 seconds ‘if’ the permanent lock is activated prior to using the oven.
So, it looks like:
* If permanent lock is accidentally activated, it will show up by automatically activating 30 seconds after using the oven (once the selection switch is in the zero position).
* Three clicks will allow the user to operate the oven. But, to cancel the feature altogether, after those three clicks, a further 6 clicks are required.
Thanks for bringing that to my attention electrofix, much appreciated. I did read through the manual, but it appears i misinterpreted the instructions.
Ps. What a hideous system!
