ENR V1661N1GB/09 FD8203
Everything works on this oven except there is no power to the fan in the main oven (although it works when i powered it myself). I cant see it being anything else but the control unit to it, or is there something im missing?
Its probably starts with a B not a V.
When you say everything work except the fan do you mean the hot air fan, “circo fan”? Is the circo element heating?
If there is no power to the fan when circotherm is selected but the heater element heats up then it sounds like it’s the control unit . I have had to replace a couple beforehand…..and they’re not cheap.
Sometimes you can see the blown track/component or even smell the ‘burning’ on the control board
