Neff intergrated washer dryer V5340 xogb/06 FAULT CODE
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Neff intergrated washer dryer V5340 xogb/06 FAULT CODE
  • #91354
    asp11
    I found some codes on here but only up to E14…… The code I have is E15
    It will select any program but won’tostart on any, checked the usual suspects and found nothing obvious – any ideas please?
    #447819
    timdowning
    Re: Neff intergrated washer dryer V5340 xogb/06 FAULT CODE
    Probably an insulation fault on the dryer element.
    #447820
    asp11
    I didn’t think to check that actually. Would this be enough to stop the whole machine from working?
    #447821
    timdowning
    Yep, same as on the Zanussi style machines.
