Neff inverter Microwave magnetron replacement
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Neff inverter Microwave magnetron replacement
  • #92692
    Twoten
    I have looked at a Neff S51M63X0B26 Microwave oven thats tripping the electrics.
    The 10amp fuse was blown and magnetron short to earth.
    Is this likely to have damaged the inverter board as well?
    #451905
    Re: Neff inverter Microwave magnetron replacement
    yes I would say inverter has failed as well
    parts are not to expensive unless you go to Neff as they are made by Panasonic
    invertors can be got off ebay and Qualtex stock the common mag
    Twoten
    I seem to remember Panasonic technical recommended changing both items even if just one was faulty but could often get away with changing the Magnetron if it was just cracked magnets.
    #451907
    if you can see the mag heater working when you turn down the lights and disconnect internal lamp chances are inverter is ok
    if its blown a fuse chances are inverter is knackered although I always try a 6.3A fuse with just inverter in circuit to see if it blows. 99{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} of the time it has
    Twoten
    Thanks electrofix,
    Mag heater on’t work as it blows the fuse immediately. I will try just the inverter with the lower rated fuse.
    With regards to the mag, I notice connect do a variety of 2M236-M42 at varying prices, cheapest being 5045175191141 at £44.52. Am I right i thinking any 2M236-M42 will work with an inverter board?
    #451909
    if that the number on the mag that’s fitted yes
    PAN2M236M42E2 qual shows this to me under £40
