Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Neff K3990 Fridge/Freezer – Beeping and incorrect operation
- This topic has 3 replies, 2 voices, and was last updated 14 years, 4 months ago by
stevelup.
December 4, 2011 at 10:31 pm #66670
stevelup
ParticipantHi
I’ve got a really weird problem with my Neff fridge/freezer.
What’s bad:-
Beeping once every three seconds. Water/Ice indicator blinks in a long pattern which I can’t decipher. I presume that is a fault indication code?
Upon opening either door, the light only illuminates until the next beep, then goes off
Water / Ice dispenser only works in one second burstsWhat’s good:-
Both freezer and fridge are at the correct temperature
Fan is runningWhat’s just plain weird:-
If you power it off at the mains, when you turn it back on, it sprays water out of the dispenser for two seconds, and tries do dispense ice at the same time.
E.nr: K3990X6GB/03
FD8612I’ve never previously had a problem with it. The failure was unprovoked – it just suddenly started beeping whilst I was nowhere near it.
Things I’ve tried are:-
Several ‘reboots’ including one where the power was left off for 30 minutes
Poking all the buttons in every possible order
Removed the ice maker and checked nothing was jammed
Both door switches are working correctly as the light comes on for two seconds when you open the door.
It doesn’t appear to be a defrosting issue. All the drains are clear and the coils inside the freezer section are free from ice.Bosch KAN58A55GB and Siemens KA58NA40 share similar electronics as far as I can tell.
Any ideas?
Thanks,
Steve
December 5, 2011 at 7:58 am #364814stevelup
ParticipantRe: Neff K3990 Fridge/Freezer – Beeping and incorrect operat
All back to normal this morning… I’ll post if it does it again.
April 28, 2012 at 8:30 am #364815stevelup
It’s been doing it again for two days solid now, so I’d like to bump this thread and beg for assistance!
Fault as described above.
Thanks,
Steve
July 13, 2017 at 6:25 am #364816ellobee
Hi, I know this is a very old post, but I have the same problem with my Neff Fridge Freezer, how did you resolve this in the end.
